1. amyf27's Avatar
    I recently got an Lg V20 to use as a backup/2nd device for myself. However, the Capture + is missingn I cannot figure out where the Capture + is or how to get it onto my 2nd screen with the other app icons.
    01-24-2018 02:01 PM
  2. jmssarno's Avatar
    Capture+ is part of the Quickmemo+ app. Make sure your Quickmemo+ app is downloaded...
    Go to Settings>Phone>Update Center>App Updates...
    Check and make sure it's downloaded and you'll be able to use the capture+ function. That worked for me, hopefully it will work for you as well.
    amyf27 likes this.
    01-24-2018 07:43 PM
  3. amyf27's Avatar
    Got it on the V20 now thanks for your help
    01-25-2018 08:39 PM
  4. jmssarno's Avatar
    You're welcome... Enjoy your V20
    01-26-2018 06:16 PM
  5. jimwavect's Avatar
    Have same issue. Have already downloaded QuickMemo and still no way to access Capture+ . Any other ideas? Powered off and restarted to see if that would work.
    06-17-2018 04:18 PM
  6. ZombiEvo's Avatar
    I had the same issue. I downloaded quickmemo but still didn't have the capture+ icon in my notification panel like I was used to. I got it worked out though.
    Once quickmemo is downloaded, pull your notification panel down. Tap the down arrow in the top right corner to expand the list of icon. Tap edit. Capture+ icon should be available to drag up with the rest of your icons.
    04-08-2019 02:41 PM
  1. What is this blue and white shield icon on my lock screen?
    Last Post: 01-28-2018, 08:59 AM
  2. What is this blue and white shield icon on my lock screen?
    Last Post: 01-24-2018, 06:04 PM
  3. My screen goes off until phone is restarted
    Last Post: 01-24-2018, 01:04 PM
  4. Replies: 0
    Last Post: 01-24-2018, 12:53 PM
  5. Is the htc u ultra on amazon.com a scam?
    Last Post: 01-24-2018, 10:56 AM
