1. geo77's Avatar
    i has anyone solved the lg. v20 service issue. radio off. & please don't suggest reboot, or putting in the code that brings up ping test because. the device imformation option 1 says not available on this device. It's not the sim. Sim info shows up on phone. Just can't use data, make calls or messages. Wifi works
    any advise would be appreciated
    06-12-2018 04:02 AM
  2. Rukbat's Avatar
    "can't use data, make calls or messages" is a carrier issue, not a phone issue, unless the SIM port is bad.
    I suggest that you take the phone to your carrier and ask them to get your account working - that's what I suspect it is, a mis-provisioned (set up incorrectly) account.
    06-12-2018 03:10 PM
  1. Blu Studio C Super Camera compatibility with Android Auto and Ford Sync 3
    Last Post: 10-05-2018, 05:02 AM
  2. Broken screen tablet how to get back in with just a cell phone
    Last Post: 06-13-2018, 01:50 PM
  3. What can I do to fix the problem?
    Last Post: 06-12-2018, 10:24 PM
  4. LG Artisto 2: Home Page keeps stopping
    Last Post: 06-12-2018, 12:11 PM
  5. LG G2 Guest Mode - can receive calls but not make outgoing phone calls
    Last Post: 06-10-2018, 08:50 PM
