    Im looking upgrading from an s5 to an lgv20 but im worried that its going to be a pain with the power button on that back when laying down or in a holder is there away around it or should i look for a different phone thanks
    11-24-2018 03:51 AM
  2. Mooncatt's Avatar
    You can double tap the screen to wake it up, then enter your PIN/password. The power button is also the fingerprint scanner, which is why you wouldn't be able to log in that way. You'll have to create a PIN or password anyway to set up fingerprint reading in case the scanner is unable to read correctly.
    tube517 likes this.
    11-24-2018 08:18 AM
  3. flyingkytez's Avatar
    No need to worry, you just double tap the screen and the screen will turn on or off. This is called LG knock and you'll find yourself using this feature way more than the back power button. If you are inside an app, you can double tap the top notification bar and it'll turn off the screen.
    FYI the V20 is one of the last NON bezelless phone.. the bottom bezel allows your thumb to rest there, thus making it possible and easier to hold with one hand and the thumb resting on the bottom bezel. On the Galaxy S5, the bottom bezel real estate is taken up by the physical home button and touch keys.
    11-27-2018 12:01 PM
  1. I receive a brief "Recording failed" notification when trying to use Voice Recorder (S9)
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 11-24-2018, 05:36 AM
  2. Android 7 & 8 TV Box can't copy & paste text in any browser
    By Android Central Question in forum Android TV
    Last Post: 11-24-2018, 03:16 AM
  3. Unknown app notification show in my notification bar.
    Last Post: 11-23-2018, 07:50 PM
  4. How to turn off auto backup for apps in Samsung J7 Prime - urgent!
    By RayRay226 in forum Samsung Galaxy J Series
    Last Post: 11-23-2018, 07:12 PM
  5. WTS: WTS: Bellroy Pixelbook Sleeve in light grey
    By jsarino in forum The Marketplace - Buy, Sell & Trade
    Last Post: 11-23-2018, 04:15 PM
