Originally Posted by
SupraLB It does appear to be downgraded or at least changed for the worse. The 120 degrees was great.
From LG website:
V20: 120 degree wide, 83 degree narrow. f/1.9 aperture
V30: 90 degree wide, 80 degree narrow. f/2.2 aperture
You have to also consider that it's a different form factor. Fitting in the same camera wouldn't make any sense. The screen to body ratio is very high (83.24%) with a brand new OLED screen. The V20 & V10 are more similar. For the V30, there's not much room above the screen to work with.
