1. Brjlk's Avatar
    Since the V30 has built in wireless charging, what wireless charger do V30 owners use?
    01-09-2018 08:32 AM
  2. Aithan's Avatar
    I second this question and related, the Starbucks wireless charging powermats work great!
    01-09-2018 09:52 AM
  3. DFranch's Avatar
    Any Qi charging mat should work. I'm using a nokia mat from an old nokia phone. In fact I've used the same wireless charger for the past 5 phones (Lumia 920, Galaxy S5, Droid Turbo, S7 Edge & V30). I love a standard that doesn't need to be replaced every year or two.
    01-09-2018 01:45 PM
  4. rfan8312's Avatar
    I use an old Belkin wireless charging pad and it works great.
    01-18-2018 12:20 AM
  5. Brjlk's Avatar
    I know there are many options out there, but what bugs me is why LG has built wireless charging into the V30 but does not produce its own charger, forcing it's users to use third party ones. It's not that hard to build a wireless charger when you can build a phone.
    milehigherik likes this.
    01-18-2018 03:52 AM
  6. DFranch's Avatar
    I suppose LG could make one and charge an arm and a leg like Samsung does.
    01-18-2018 08:45 AM
  7. rfan8312's Avatar
    I bought a Samsung wireless charging pad new.on Amazon for.around 30.bucks. not the fast charge one.
    I Iike the Belkin better. It's wider and flatter. They both work.great what's the big deal. Just get a Belkin.
    01-18-2018 09:24 AM
  8. cd619's Avatar
    Factory charger with a cheap fast-charge ebay stand.... works fantastic.
    01-26-2018 06:08 AM
  9. TheMarcus's Avatar
    They did for the G3, but sold it to very limited markets. LG is terrible at supporting their phones with accessories so don't ever expect anything from them, but disappointment if you want more than just the phone. 🤣
    01-31-2018 01:26 PM
  10. Rukbat's Avatar
    When you can buy a generic Qi pad for under $10 (and mine is still working 4 years later), they probably figure that they'll make more money by putting the effort into phones, not charging pads.
    Buddy1969 likes this.
    01-31-2018 03:11 PM
  11. Brjlk's Avatar
    Your charger is very durable. What is the brand?
    02-01-2018 12:30 AM
  12. Buddy1969's Avatar
    ^^This
    BTW does anyone know QI charging pads that support fast charge? Is that even possible with the V30?
    02-01-2018 01:05 AM
  13. mkreef's Avatar
    Check out this thread if you want to make use of fast wireless charging, very few pads support the new standard in the V30:
    https://forum.xda-developers.com/lg-...rging-t3687478
    After reading that thread, I went with the omars 15w:
    https://www.amazon.com/gp/product/B0...cUvbUpU6153687
    (Requires a quick charge 3.0 plug).
    It reports "fast wireless charging" (or whatever, I forget the exact phrase).
    02-03-2018 06:23 PM
  14. Brjlk's Avatar
    https://www.amazon.com/gp/product/B0...cUvbUpU6154079
    Is the plug that comes with the V30 a quick charge 3.0 one?
    02-04-2018 08:01 AM
  15. mkreef's Avatar
    Not sure. The omars pad requires a micro USB, so I didn't even try -- I just picked up a QC 3.0 wall adapter.
    02-04-2018 11:16 AM
  16. Brjlk's Avatar
    Thanks. Give us some feedback about your new wireless charger
    02-04-2018 12:46 PM
  17. Brjlk's Avatar
    LG Introduces quick 15 watts wireless charger
    02-05-2018 05:48 AM
  18. Buddy1969's Avatar
    ... I went with the omars 15w:
    https://www.amazon.com/gp/product/B0...cUvbUpU6154783
    Thanks. Just ordered this from Amazon. Can I use the V30 charger and just plug the Micro-USB cable in?
    02-05-2018 07:48 AM
  19. edhdurham's Avatar
    Hi,
    Looking for a Wireless Charger and my girlfriend already uses this for her S8:
    https://www.mobilefun.co.uk/official...le-black-63094
    I have tried it and it charges my phone but I was worried about long term damage to my battery if it is not fully compatible, watched MrMobile do a review on charges including the above Samsung and he says that he uses in the office as his standard Qi charger, but didnt specify definitively if it is compatible... does anyone know?
    02-14-2018 03:00 PM
  1. i have a note 5 what phone cases will work well with a wireless charging pad?
    By Android Central Question in forum Samsung Galaxy Note 5
    Last Post: 01-31-2018, 03:13 PM
  2. Replies: 27
    Last Post: 01-19-2018, 07:46 PM
  3. Is there a way to get the Note3 Multiwindow side bar on the note 8?
    Last Post: 01-09-2018, 04:55 PM
  4. Replies: 1
    Last Post: 01-09-2018, 11:49 AM
