1. Mike Dee's Avatar
    The big advantage of a sealed battery is the phone is waterproof. Btw my V20 was damaged by water.
    I also read that to keep it in good health, a battery should not be left too depleted nor fully charged. In this case a wireless charger is a good option to monitor the amount to charge a battery.
    Why is a wireless charger a good option to monitor charging?
    02-12-2018 08:46 PM
  2. vasekvi's Avatar
    I'm loving this thing I picked up on Amazon for 29.99
    https://photos.app.goo.gl/fJ3ixJoi6Qk6GiX13
    02-12-2018 08:51 PM
  3. marcus.plans's Avatar
    ... the power bank is a good alternative. You will be able to use the phone while it is being charged.
    I have a 4 year old 10,000 mAh power bank and it charges my V30 from 15% to 100% in just 2 hours. Newer power banks with higher output should do better.
    A power bank is not a good alternate. It's the only one. A bulky power bank is a terrible replacement for a slim battery. An hour to charge is a terrible replacement for a one minute 0-100% battery swap.
    FORTUNATELY the V30 has great battery life. Not missing removable as much as I thought I would. Would have preferred they went with at least 4,000 mAh, though, and I'd love to see 5,000 mAh on a flagship in the future. If LG was serious about competing and sticking out, they'd compete with unbeatable battery life, but, just like every other OEM, they settle for "just enough".
    Phones with removable batteries can be water proof.
    Snapdragon 835 is indeed much more power efficient. Give it 1-2 years. The V20 will outlast it with a fresh battery.
    My V20 with a fresh battery still has terrible battery life. In two years, though, a V20 with a fresh battery might outlast a V30 with an old one. Maybe. Maybe not. I will definitely take advantage of my extended warranty and have them swap the battery out for me.
    That's great, if you can find an OEM battery. Aftermarket batteries are hit or miss on longevity, and re-sealing the device is another story.
    I've had great experiences with Hyperion and TrendOn batteries for the G3 and G4. In fact, those batteries have been better than my LG batteries on those devices and the OEM battery for the V20 is the worst I've ever experienced. 3 out of four of my V20 batteries die around 20%. Never had that problem before with any phone.
    02-13-2018 06:34 PM
  4. chanchan05's Avatar
    There's still the powerbank cases, or if you have a Motorola, a battery mod. Since you're not supposed to drain your battery to zero its not a big deal. Activate the power case at 50% and you're good.
    They settled for looks. Remember how huge the original Razr Maxx was relative to screen size? It was heavy with huge bezels and thick. It was advertised as a rugged phone so its ok. But today's flagships are focusing on premium looks. Samsung does have an alternative with the Active series with the same flagship specs with 4000mah batteries but they're not so widespread. I'd take one if they were available in my country.
    Not for long. The difference is that every time you open it up and change the batteries you put wear on the seals. If your purpose of having the removable battery is swapping batteries throughout the day, the waterproofing won't last long.
    02-13-2018 08:45 PM
  5. marcus.plans's Avatar
    This is the V30 forum, right? Moto mods are not an option here. Battery cases make the phone more unwieldy than a phone with a removable battery using am extended battery usually. I've only seen one option on Amazon for the V30 and reviews said it was slippery so that's no good.
    A bigger battery just means the phone would br a bit thicker. That wouldn't sacrifice looks, especially since nobody asked for razer thin phones while. These phones are so thin now that they could easily sell them with larger batteries without sacrificing looks or ergonomics.
    02-13-2018 08:58 PM
  6. chanchan05's Avatar
    Actually a thicker phone will sacrifice ergonomics, With the screen sizes we have now. A Note 5 has a bigger screen for example than a Note 2 but footprint is nearly the same. And yet the thicker Note 2 is more unweidly.
    This is actually where the narrower 18:9 ratio is coming in. The footprint of the S8 IIRC is smaller than the S7 but it has a bigger battery.
    So hopefully as they upp screen sizes we also see bigger batteries. Although if battery life was a major concern I'd say go for a modern mid ranger instead of a flagship
    02-13-2018 09:06 PM
  7. marcus.plans's Avatar
    Going from 3300 to 4000 or even 5000 on the V30 would not sacrifice ergonomics. This phone is extremely thin. I used a 6000 mAh extended battery on both the G3 and G4 and, in my opinion, the phones were actually easier to use because that bump filled your palm. My girlfriend disagreed, but that's a battery twice the size. Not a third bigger. A bump to 4000 would be fine with room to spare.
    02-13-2018 09:09 PM
  8. chanchan05's Avatar
    The fact that your gf disagreed meant that it's not meant for everyone, and not everyone feels the same way as you. Considering LG is a Korean company, I'd imagine a lot of the designers are Koreans with smaller hands than most Caucasians.
    But I agree the bump wouldn't be too big on a few 100mah. A prime example is the S6 to the S7. That's a 400mah bump in battery in exchange for like 1 millimeter but retained almost all of the other dimensions.
    02-13-2018 09:14 PM
  9. marcus.plans's Avatar
    6000 vs 3000 is a huge difference.
    4000 vs 3300 is not.
    And speaking of smaller hands... When the Note was first released, I only ever saw tiny Asian women using it so I don't small hands is a great argument here. Especially not when larger phones are the most popular ones for everyone using Android or iPhone.
    02-13-2018 09:17 PM
  10. flyingkytez's Avatar
    So what would you do if your non-removable battery is depleted, you have no wall charger around & you really need to use your phone?
    Today power banks use Quick charge 3.0, have a capacity of up to 30,000 mAh, so can charge 6 times a V20 or V30 before they need recharging.
    I don't think a phone dies when the battery dies. Non-removable batteries can be safely replaced at a service center.
    A good battery should last more than 2 years. My 4 year old Samsung Note 2 still works correctly with the original battery
    I have a spare battery that I carry around. I actually have 4 spare batteries already charged. I only need to swap once per day anyways. The battery itself is super slim, can fit in your shirt pocket. Just takes 15 seconds and I get 100%, meanwhile you're using your phone WHILE it's charging and plugged in... some phones like LG SLOWS DOWN and throttle the speed to avoid overheating.. so you get reduced performance plus a hot battery.. hot battery equals lower battery life expectancy. And no, once you go to a service center to replace your battery (probably costs $100 the cheapest), the phone is no longer waterproof.. so it's not even worth the trouble.
    Plus I have a quick charge 3.0 charger in my car.. it charges SUPER fast. If I plan to go somewhere that I know I won't have access to power, I'll bring some spare batteries with me in my pocket.
    But dang, imagine if the 30,000 mAh caught fire in an accident.. you're looking at a hand grenade... Plus the metal chassis will scratch and damage your phone if you have it together.
    I still love LG and respect their decision to have sealed batteries.. but I'm still benefiting from removable batteries and enjoying the extra freedom.
    02-14-2018 09:45 AM
  11. MA2GA28's Avatar
    Do you worry about your spare batteries catching fire in an accident, or spontaneously combusting in your pocket?
    Also, you said you have 4 spare batteries. Probably cost you, at least, $60 or more for all of them. All so you can put them in your phone that has absolutely no water resistance. Yet someone spending about $100 to have a battery replaced in their phone is not worth it BECAUSE it would lose the IP rating?
    You are just cherry picking arguments to support your view at this point, creating "problems" with the counter argument that aren't a real concern.
    The fact is, you're coming into a forum of a phone that you don't even own to start controversial thread topics.
    areyes163 likes this.
    02-14-2018 10:13 AM
  12. Brjlk's Avatar
    Well, you look at the battery gauge in the Task bar. If it drops below 30%, you place the phone on the wireless charger. If it reaches 80% to take it off.
    02-14-2018 11:49 AM
  13. MA2GA28's Avatar
    I think his point was that you can do the same with a plug charger. Just buy a $5 phone stand.
    02-14-2018 12:44 PM
  14. Brjlk's Avatar
    Not as convenient.
    If you move around in the office or make a call you will need to unplug the phone.
    02-14-2018 07:41 PM
  15. Brjlk's Avatar
    Finally it comes down to whether you like wireless charging with its pros and cons
    02-14-2018 07:44 PM
  16. marcus.plans's Avatar
    Wireless charging is great if you work at a desk since your phone can charge any time you're not holding it with no hassle of plugging in. Set down, charge. Not a good setup if you're on your phone more often than not, but I'm sure that's not the case for everyone.
    02-14-2018 09:33 PM
  17. MA2GA28's Avatar
    Not as convenient.
    That may be, but you said it's convenient for monitoring the charge. So Mike Dee asked why, and the reason you gave can be accomplished with a plug in charger just as conveniently. And having to unplug a phone is hardly inconvenient for most.
    Personal opinion is key here, of course, but you seem to present your points as if they are cut and dry.
    02-15-2018 06:31 PM
  18. Mike Dee's Avatar
    I have no issue with people preferring cordless charging, however I don't see how that's an improvement as related to monitoring charging.
    02-15-2018 11:57 PM
  19. Mike Dee's Avatar
    FORTUNATELY the V30 has great battery life. Not missing removable as much as I thought I would. Would have preferred they went with at least 4,000 mAh, though, and I'd love to see 5,000 mAh on a flagship in the future. If LG was serious about competing and sticking out, they'd compete with unbeatable battery life, but, just like every other OEM, they settle for "just enough". Phones with removable batteries can be water proof. My V20 with a fresh battery still has terrible battery life. In two years, though, a V20 with a fresh battery might outlast a V30 with an old one. Maybe. Maybe not. I will definitely take advantage of my extended warranty and have them swap the battery out for me. I've had great experiences with Hyperion and TrendOn batteries for the G3 and G4. In fact, those batteries have been better than my LG batteries on those devices and the OEM battery for the V20 is the worst I've ever experienced. 3 out of four of my V20 batteries die around 20%. Never had that problem before with any phone.
    Fast charging power banks don't take that long.
    02-15-2018 11:59 PM
  20. marcus.plans's Avatar
    Takes as long as a fast charging wall charger which, according to Phone Arena benchmarks, is 108 minutes for a full charge.
    02-16-2018 12:50 AM
  21. chanchan05's Avatar
    Except you were never supposed to charge from zero anyway when using a phone. To take care of it properly you need to be charging at 40% or above and stopping at below 90% unless circumstances make that impossible. Having a power bank means you can do that. 50 to 90% should take around an hour. Depending on what I've been doing I usually have between 40-60% come 12nn at lunch time (yeah my phone is heavily involved in my current job). I plug it in on my break. I won't be talking on the phone while eating. When I'm done it's back at 80-90%.
    Also when you're out in places without a charger, chances are you're doing something else, so you have time to leave your phone alone to charge.
    All arguments saying swapping batteries is better because it's faster on an emergency when you're in an emergency call and the phone dies doesn't cut it simply because it's only a better option when you're draining the battery to zero, which you shouldn't be doing in the first place. Your phone shouldn't be reaching the point where it might die in the first place. Plug it in a 50% while you're doing something else, just like when you're at home.
    02-16-2018 05:55 AM
  22. Mike Dee's Avatar
    You don't always need a full charge.....too each his own
    02-16-2018 09:23 AM
  23. marcus.plans's Avatar
    Except you're both entirely ignoring the point which is a removable battery is just far more convenient and versatile. Period. There is no arguing that. It's an instant recharge and it's zero bulk. That's it.
    If you have to spend an entire day out sight seeing, taking pictures, using navigation, whatever, being able to swap batteries is infinitely better than lugging around a hulking power bank, USB cable, and/or wall charger.
    There really is no arguing that point. An extra battery or three isn't even noticeable in a pocket whereas a power bank or wall charger along with its accompanying USB cable would be impossible to ignore and they still require you to keep your phone either tethered for an extended period of time or tethered multiple times.
    Sure, if you're carrying around a purse, it's probably a moot point since you could have your phone in the bag charging while idle, but for everyone else who only has their pockets to carry things, a power bank isn't a good alternative — it's the only one.
    02-16-2018 11:04 AM
  24. MA2GA28's Avatar
    Sorry, but presenting your stance as inarguably the right stance is just just flat out incorrect.
    It's not convenient to have to worry about remembering to grab extra batteries, charging the extras, and making sure you know which are charged and which aren't. Then having to carry around an extra charger when one travels? PITA if you ask me. And having to spend extra on batteries? No thanks.
    And tie that all in to the complete lack of IP rating, which is important to many people, I think carrying around the added bulk of extra batteries is not convenient at all.
    02-16-2018 11:31 AM
  25. Mike Dee's Avatar
    Sorry but to each his own.... Being out all day a power pack works better for me. I've done both even with the V20. It's kind of irrelevant since removable batteries are most likely not coming back.
    02-16-2018 11:50 AM
66 123
  1. Is Android such a simpleton that you can not disable or remove the guest account?
    Last Post: 02-01-2018, 06:52 PM
  2. What does a text message received from someone in the line on the side is grey
    Last Post: 02-01-2018, 06:49 PM
  3. Replies: 2
    Last Post: 02-01-2018, 06:42 PM
  4. Replies: 1
    Last Post: 02-01-2018, 02:22 AM
