1. edhdurham's Avatar
    Hi,
    My girlfriend has this wireless charger for her S8:
    https://www.mobilefun.co.uk/official-samsung-galaxy-wireless-fast-charger-convertible-black-63094
    I have tried my LG V30 and it seems to charger ok but I am worried about long term battery problems if it is not compatible... is there an official list of what wireless chargers to use with the LG V30 device?
    Thanks
    02-14-2018 01:18 PM
  2. Brjlk's Avatar
    If you click on the Compatibility tab from the link you provided & go to LG, you will find the V30.
    Some questions about the charger:
    Does it heats the phone?
    How fast does it charge?
    Thanks
    02-14-2018 06:36 PM
  3. edhdurham's Avatar
    Ah, what muppet I didn't see that tab!!! Cool so they say its compatible, I messaged Amazon and someone said they were using it for their V30...
    02-15-2018 04:41 AM
  1. Replies: 1
    Last Post: 02-11-2018, 09:51 PM
  2. Why is my LG Aristo locked on master reset reboot screen
    Last Post: 02-11-2018, 09:23 PM
  3. Dumb Question
    By JC8865 in forum Ask a Question
    Last Post: 02-08-2018, 11:33 PM
  4. LG 4G (VS985 4G LTE) DAC Replacement?
    By Cool Javelin in forum Ask a Question
    Last Post: 02-08-2018, 03:48 PM
  5. How do I factory reset the LG k20?
    Last Post: 02-08-2018, 12:12 PM
