1. neil74's Avatar
    Should say sync headphone and v30 volume!
    Has anybody managed to get headphone and device volume synced on the V30?
    On Bluetooth headphones the volume operates independently and I would prefer to sync them up like they are on the pixel or can be on the S8.
    02-19-2018 01:13 PM
  2. Rukbat's Avatar
    On most phones, the headphone volume is reduced as soon as you plug the headphones in (to keep from damaging your hearing - and trust me, a single blast of loud noise in an earbud can cause incurable loss of hearing). There's not much you can (or should) do about that.
    Bluetooth volume isn't independently settable - it's set by the media volume - which is also what you're probably using the headphones for.
    So bottom line - you can't do what you want (and you shouldn't).
    02-21-2018 03:52 PM
  3. neil74's Avatar
    I think you misunderstand? My issue is that the volume is independent I.e. volume on headphones does not control volume on the phone, you can adjust both.
    How it works on the pixel (how it works out of the box) and also on Samsung via media volume sync.
    02-22-2018 02:44 PM
  1. Why is it ppl can hear me but when i go to spr phone no one can hear me..
    By Spitfire1963 in forum General Help and How To
    Last Post: 02-19-2018, 03:00 PM
  2. Why i cant get porn on my phone
    Last Post: 02-19-2018, 02:16 PM
  3. Unlock Verizon phone?
    Last Post: 02-19-2018, 01:10 PM
  4. problem with replacing display on z5 compact
    By tattri in forum Sony Xperia Z5 & Z5 Compact
    Last Post: 02-19-2018, 10:40 AM
  5. How does accessibility mode get turned on with shortcuts disabled?
    Last Post: 02-19-2018, 09:01 AM
