1. forloveofthegame's Avatar
    After 5 months with my 3rd (YES 3RD) replacement V30, it suddenly won't connect to home wifi. Tried forgetting network and rebooting. Still won't connect. Waiting to see if work WiFi will be the same way. Other home devices connecting perfectly. Last time I ever buy LG.
    07-09-2018 07:19 AM
  2. DFranch's Avatar
    Have you tried rebooting the Home Router?
    07-09-2018 08:38 AM
  3. ManiacJoe's Avatar
    Check the router settings to make sure the DNS allowances are big enough to allow all your connected devices.
    07-09-2018 01:21 PM
  4. Rukbat's Avatar
    I don't know about the V30, but I had a V20, and it connected (and stayed connected) just fine for months. And the router I use is the second cheapest one on the market (I don't buy Trendnet.) So it's not LG. If your carrier has a brick and mortar store, see if they can help you. Most cellphone stores have in-house wifi, even if they forget the connection after they fix what's wrong with yours. (They don't want you sitting outside connecting to their LAN - it's a security risk.)
    I've also had a few other LGs, going back to the first flip phone with a camera. And never had a problem with wifi with them.
    The problem is that troubleshooting a wifi problem can be impossible enough if you're there - doing it remotely like this makes it just that much more difficult. But, as Joe said, check to make sure that your DHCP (not DNS) server (in the router) has at least one open slot. (By default, all 253 are open, but some people, who understand how things work, restrict them to what's needed. So if you have 3 devices plus your phone, and you have 2 connected, the phone has no trouble connecting - it gets that 3rd slot. But if all 3 devices are connected, then you try to connect the phone, there's no IP address for it. [The DHCP server assigns IP addresses to devices as they connect.])
    Of course there are many other possibilities. (One we can eliminate is that the phone can't handle the form of encryption. Some phones have a problem with some implementations of TKIP. But that phone connected to that router, so that's not the problem.) Also, place the phone on the router and try to connect. (I'd be amazed if that's the problem, but if your luck is bad enough, you could have gotten 3 phones in which the wifi antenna became disconnected after a while.)
    Laura Knotek likes this.
    07-09-2018 05:14 PM
  1. hd widgets- weather not updating - lg k8
    Last Post: 07-18-2018, 01:58 AM
  2. Why can i not receive a text from my bank
    By Tony Hodgkin in forum Android 8.0 Oreo
    Last Post: 07-09-2018, 09:12 PM
  3. how to turn off the do not disturb ikon; i cant get incoming calls to ring
    Last Post: 07-09-2018, 07:12 AM
  4. How can I not watch porn
    By stuart cunningham in forum Ask a Question
    Last Post: 07-08-2018, 06:42 PM
  5. Want to get rid of extra info under available WiFi networks?
    Last Post: 07-08-2018, 06:22 PM
