1. jamielov's Avatar
    Phone wont charge anymore past 94%. Ever. No matter how long it is charging. Also depletes like crazy. In the time it took to open this page and type this message, battery dropped to 89%.
    Any ideas where I can look to see what it going wrong?
    09-29-2019 08:42 AM
  2. WillyWonka's Avatar
    Get your battery replaced. It will kill the waterproofing, but will fix your battery problems more than likely
    09-29-2019 11:12 AM
  3. NationalTrust's Avatar
    First thing I would do is a factory reset.
    09-30-2019 03:43 AM
  4. mccornwall's Avatar
    I had excessive battery use after the update. I went thru the pain of doing a factory reset. No help whatsoever. Need a fix pushed out.
    10-07-2019 08:04 AM
  5. dookie.'s Avatar
    No issues here, FWIW.
    10-07-2019 10:37 PM
  6. Rumblee1's Avatar
    I've always had great battery life on my V30. I still make it through a whole day without issue, but there's about a 5-10% more drain than before the update.
    ManiacJoe likes this.
    10-08-2019 02:39 PM
  7. fwaits's Avatar
    Mine actually seemed to get slightly better after the update. I was slowly losing life per day recently, and it improved a bit after the update. It definitely didn't get worse for me.
    10-11-2019 05:49 PM
  8. gray2018's Avatar
    I've always had great battery life on my V30 as well. On T-Mobile and after the update, I noticed my battery life has steadily gotten worse.
    10-16-2019 07:57 AM
  9. ManiacJoe's Avatar
    You guys having battery issues: Are the battery statistics giving you any info on what is eating more power?
    10-16-2019 01:59 PM
  10. mccornwall's Avatar
    Not really, just standby
    10-17-2019 07:53 AM
  11. gray2018's Avatar
    Not only am I having battery issues, I am also having issues with service. Even wifi. Places where I had great wifi service before, I am barely getting any now. wtf. gee, I was all excited about 9.0 but should have just left it alone.
    10-17-2019 10:55 AM
  12. ManiacJoe's Avatar
    Now that you mention it, that does seem to be marginally higher now.
    My house does not have the greatest signal strength with ATT, so I usually have wifi calling turned on, which seems to help a little.
    10-17-2019 01:15 PM
  13. fwaits's Avatar
    Might be a good idea to backup things and do a reset. That may help things out unless you have a hardware issue, but I doubt that since it started with the update.
    10-18-2019 01:21 AM
  1. why do apps update as soon as I have moved them back to SD card?
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 10-16-2019, 02:11 AM
  2. Why am i not seeing updates for my s9+
    By Joseph Henshaw in forum Samsung Galaxy S9 & S9+
    Last Post: 09-30-2019, 08:09 AM
  3. Replies: 5
    Last Post: 09-29-2019, 09:39 PM
  4. Why am i not seeing updates for my s9+
    Last Post: 09-29-2019, 06:39 AM
  5. why do apps update as soon as I have moved them back to SD card?
    Last Post: 09-28-2019, 04:47 PM
