Vibration in battery saver mode?
thumper4524
12
Is there any way to use battery saver mode and still have the V40 vibrate on notifications, calls, etc? I can't find an exclusion to allow it, battery saver mode will be useless to me.
cj993
9
Nope. You can not use battery saver mode with vibration at the same time. That's part of the battery saving to disable vibration. It takes a decent amount of juice to spin the vibration motors so they're trying to save battery that way.
wei34
