hope so otherwise your problem going drive me crazy lol
I know right? It's the weirdest thing I've ever seen. I can download ANY 3rd party app a d it works, but T-Mobile is trying to tell me that a new Sim card is going to fix it lol
Lol..I expect that from carriers that don't dive in deep into troubleshooting.I know right? It's the weirdest thing I've ever seen. I can download ANY 3rd party app a d it works, but T-Mobile is trying to tell me that a new Sim card is going to fix it lol
Keep testing , let me knowIt's too early to tell, cuz it's done this before, but I think you fixed it buddy! Just received a totally inappropriate meme from a friend no problem.
That kind of blares out in color "it's the stock app". The LG app may just not work with TMobile for some reason.Yes MMS works on Google messages, which is what I'm currently using, but I'd prefer to use the stock app
BTW, the Google SMS app definitely does do RCS on TMobile. Pixels (which use the Google app) work fine on TMobile.
Is it still working ?The stock app works for other people in TMobile. And I know that Google messages does RCS on T-Mobile.. But as I've mentioned, I prefer the stock app if I can get it to work.
yeah for some reason yours has a bugNope, conked out after about an hour. And even then MMS was working, but T-Mobile RCS wasn't. I think I'm stuck with Google messages lol
Yeah definitely your welcome!Appreciate all of your help.. we gave it one hell of a try
You don't have a option for automatic? Looked at mine and set to that , also if you turn WiFi calling off does it work? , I know Att had issue like that .Pretty sure it's private dns. With it turned on, doesn't matter which dns, it doesn't work. Starts working again as soon as it's turned off. That's a huge network issue for T-Mobile
It's possible that the stock message app doesn't play well with that ad guard.Yeah I have the option for automatic, and it works when it's set to that. But it defeats the purpose of a private dns. I have been using either adguard dns, or cloudflare ever since the feature was introduced in Android with no problems. But it definitely stops working as soon as I turn it on
Yep, I use it regularly and have had zero problems. Sorry that you're having such bad luck!
Yeah most likely!
