T-mobile A11 incoming
THey have a bunch of themed keyboards for the LG keyboard.
The one you and I saw is the "Ambient" function that lets it change colors.
I just found this by accident lol
Also the LG keyboard has a clip tray or "clipboard" built in.
Although I have the option set, my stock LG keyboard does not predict the next word for me. I see the keyboard has changed and I'd like to try it out but I want the prediction feature to work before I switch.
Did they remove the option to change the resolution? I had mine running in 1080 and my icons were bigger. Now they are back to the smaller size and i cant find anywhere in the display settings to change it. I mainly ran mine in 1080 as it was a bit more battery friendly.
The V60 only has a 1080 panel. Everyone is running it in 1080 since it doesn't go any higher
Gboard and Swiftkey are the best at word prediction. LG made some improvements but they won't be as good as those 2
I really been trying to use the LG keyboard but it's just not as smooth or accurate as gboard. Looks like I'm going back.
Had put my phone down for a while and have been using my Note 10+. Up graded to Android 11 and now my LG dual screen app is basically useless. Can only select a very few apps and none of the ones I used to use. Anyone else seeing this problem? Thinking about reseting phone. Thanks
Edit: Looks like the developer knew about the issue and has fixed this issue with an update.
Ashok Dharshan
