1. tardus's Avatar
    A few days ago I got a system message that internal memory was nearly full, which is highly unlikely.
    From storage AFTER deleting (and noting) over 25 apps -
    Other apps 82 GB
    Files 5.9 GB (I store all data possible on a 256GB SD card
    Other apps 82 GB (!!!)
    Files 5.9 GB
    System 30 GB
    This is after I deleted all unessential apps and it's impossible that this amount of space could be used. After deleting dozens of apps used space was reduced 97% full -> 93% full, still not acceptable since it's best practice to lease a good amount of internal memory free.
    A few months ago 50%+ of storage was free, as opposed to the above.
    From system->App info most apps are less than 100mb and only a handful are 400mb or so.
    Cache and all extra were also deleted and moved elsewhere.
    Any ideas what else I can try? I want to avoid resetting and reinstalling everything. My phone is critical for work.
    Thanks!
    11-17-2021 02:34 PM
  2. B. Diddy's Avatar
    Check all messaging and social media apps to see if they've built up enormous amounts of cache or data. Telegram and kik are common culprits.
    Also try running DiskUsage to get a better idea of what's taking up space.
    11-17-2021 02:54 PM
  3. tardus's Avatar
    Thanks, I should have mentioned the only social media that I use is Twitter, and that is using very little space. Telegram is rarely used and uses only 75mb including data. If I have to use FB, I just use a browser. And I only have two games, both less than 100MB and disabled the stock games which can't be deleted.
    Adding up for each app (app and data, cache cleared) should be well under 20GB, not 80GB! Of course the 80GB includes some system apps and TMO apps that are not removable. Most TMO apps are disabled.
    Is 30GB for system (see my first post) to be expected? That looks like a lot but never noted in the past since main memory was always less than 50%.
    11-17-2021 03:10 PM
  4. B. Diddy's Avatar
    30 GB might be high, but it can depend on how much total storage the phone has. If it's a 256 GB version, that might be a reasonable figure.
    11-17-2021 03:26 PM
  5. tardus's Avatar
    It's 128GB version.
    My theory is residual junk left over after Android version updates.
    11-17-2021 03:48 PM
  6. B. Diddy's Avatar
    Unfortunately, there's no way to wipe the cache partition on LG phones, so a factory reset might be the next step.
    tardus likes this.
    11-17-2021 04:11 PM
  1. Ringtones on Moto One Fusion w/ Android 10
    By viben in forum General Help and How To
    Last Post: 11-17-2021, 05:55 PM
  2. Problem with google account + contacts app
    Last Post: 11-17-2021, 03:51 PM
  3. Is Android 11 Safe to Use On My New Note 20 Ultra?
    By Shadow8787 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 11-17-2021, 03:17 PM
  4. Trackpad not working in Android (10 + 11)
    Last Post: 11-17-2021, 10:05 AM
  5. android app version
    Last Post: 11-17-2021, 08:51 AM
