R34SKYLINE
97
I reseted my phone last night, And now i can't download apps that i had purchased! What the hell. It shows the price instead of download :( and yes i logd in my original google account.
And also now ny phone docent want to connect to sprints 4g lte network :(
Sent from my LG-LS840 using Android Central Forums
R34SKYLINE
97
And.if i click the price like if i were to buy it, it gives me this
alog122
98
Make sure 4g is enabled under mobile networks and try clearing the cache and data of the play store and restart your phone re input your gmail account info. And see if that works. If not try a factory data reset and if its still no dice. Go with the un-brick method.
R34SKYLINE
97
The play store thing it's fixed now. But still no 4g I do enable the 4g setting but nothing it docent even connect to 3g while it's on the 3g/4glte setting
Sent from my LG-LS840 using Tapatalk 2
alog122
98
Hmmm try dialing the activate code (I don't remember what it is other than it starts with a *) if that's a no go then I would just make a backup and do a factory reset. If all else fails do a debrick. That should fix it.
libertus77
137
Did you do the Activate this device in the main settings menu? I heard you had to do that for 4g after reset. Since I still have no 4g, I can't say for sure.
Sent from my V6Supercharged ICS-Flavored LG Viper using Tapatalk 2
Mellimel22
Banned
Mar 1, 2012
2,447
41
Exactly same thing happened to me and make sure your time is updated
Sent from my Sprint Galaxy Nexus Rockin 4.2.1 using Tapatalk 2
R34SKYLINE
97
I went to the active this device and updated the prl and profile then the 4g started working! Thanks allot guys :D
wormy987123
flashaholic
Aug 31, 2011
393
29
Has anyone had issues with data not working of they leave the setting set to lte/CDMA? If I put it on cdma only it works fine.
libertus77
137
I did have that problem a week or so ago.
Sent from my V6Supercharged ICS-Flavored Bionic using Tapatalk 2
dark_mirage
366
It still works, it's just that you're in an area of low LTE, and it compensates by swapping back and forth between LTE, and CDMA, usually causing more harm than good.
Sent from my LG Viper 4g LTE using Tapatalk 2
Mellimel22
Banned
Mar 1, 2012
2,447
41
Naw that was sprints issue because multiple users data was acting funny ALL on sprint I updated my time and profile and prl and it fixed itself lol
thenameisnigel
1,446
148
63
That's why WiMAX will always be the best. May not be fast, but Sprint did a great job with the rollout.
- - - Updated - - -
anon(94115)
Banned
Nov 29, 2010
5,697
511
I know it is not widespread yet and maybe it is just my area, but they have done a decent job over the last few months in my are with LTE. I have pretty much watched it roll out and it is about a mile from my house. Once in awhile when I have wifi off I see it flicker for me. I am guessing that my whole area will be covered by Q2 of next year.
Mellimel22
Banned
Mar 1, 2012
2,447
41
- - - Updated - - -
Lol bro clear handled the wimax rollout
