1. adrianh's Avatar
    For the article "Best Smart Light Switches That Don't Require A Neutral Wire in 2020" (https://www.androidcentral.com/best-smart-light-switches-dont-require-neutral-wire), it states:
    > There's a reason why almost every smart switch needs a neutral wire attached.
    > Smart switches that work without a neutral wire need to connect through a bridge or hub because of the programming — things like your wireless network details and login — are stored in the hub and not a microcontroller inside the switch.
    This kind of implies that it is a programming necessity, which it is not. This could be done using an EEPROM on the device itself. AFAIKT, a hub is merely a control gateway which tells the devices what to do, similar to the cloud server used by those devices that don't require a hub. Is this correct?
    08-04-2020 01:04 PM
  2. B. Diddy's Avatar
    I moved this to the Lighting & Home Management forum for more specific traffic.
    08-04-2020 10:49 PM
  1. How can I lock my settings so they don't accidentally change?
    Last Post: 08-04-2020, 11:46 PM
  2. Replies: 2
    Last Post: 08-04-2020, 01:37 PM
  3. Any way to view history of the Text Browser?
    By lucasnooker in forum Ask a Question
    Last Post: 08-04-2020, 01:21 PM
  4. Whats the tiny dot at the top of my notifications screen?
    Last Post: 08-04-2020, 12:06 PM
