1. missionsparta's Avatar
    Anyone else have an issue when you try to use Samsung Connect to change your thermostat temperature? I can change it one degree, then the waiting circle icon comes up and just hang. When I back out and come back in the thermostat has moved the one degree and is good to go again, but once again I can only move it one degree and will get the waitinf/hanging icon.
    11-23-2017 11:15 PM
  1. Redmi 3S prime phone opening and closing apps automatically.
    Last Post: 11-24-2017, 04:51 PM
  2. my screen is black and blocked huawei p7
    Last Post: 11-24-2017, 04:47 PM
  3. Answering calls fails when bluetooth device connected
    By Android Central Question in forum Huawei Watch
    Last Post: 11-24-2017, 04:46 PM
  4. Samsung Gear Fit 2 causing problems
    By drusmom in forum Samsung Gear Fit 1 & 2
    Last Post: 11-23-2017, 10:34 PM
