1. miner_films's Avatar
    Device info:
    Brand: Samsung Galaxy S2
    Model: GT-I9100
    CyanogenMod version: 12.1-20150905-NIGHTLY-i9100
    Android version: 5.1.1
    So I've noticed that whenever my device seems to crash and I have to hold the power button to turn it off. When I turn it back on the phone states that my battery is low and that I should plug in my charger.
    I'll use my most recent crash as an example, so I was watching a YouTube video it got to about halfway through before it stopped. Now I first thought that the other half of the video hadn't loaded yet, so I tapped the screen and got no response.
    I tried the home button and the back button (of course with a delay before pressing the other), but still nothing happened. So I held down the power button to turn the device off (despite the phone being frozen that's the only button that works), I turned the phone back on and surprise surprise my phone has 1% in battery left.
    Now I don't know if this is because my apps are by default installing to the internal storage and I have to manually move them to the SD card or if the phone needs a new battery.
    I'm updating to the latest version to see if it runs any better.
    09-13-2015 01:20 AM
  2. miner_films's Avatar
    So I updated to CM version: 12.1-20150912-NIGHTLY-i9100
    So not long after my phone updated its fps dropped to 10 (I don't have an actual clue how far it dropped, this is just an example number) and then slowly dropped to zero, to where I had to turn the phone off and then back on.
    After I've backed up the games on my phone, I'll uninstall all the games on my phone and see if this changes anything.
    09-13-2015 08:07 AM
  3. Cyngn Ray's Avatar
    Hi there, I would pursue a new battery as one for that model is pretty cheap on Amazon or other outlets. Reading your description makes me thing the battery itself may be going bad. Either way, if it's not the battery you have a good spare. When you get the new battery, if the behavior persists, I would do a clean flash of the device after backing up data. If the issues STILL persist, I would roll back to an earlier nightly.
    09-14-2015 08:53 AM
  4. miner_films's Avatar
    OK, after uninstalling the 24 games I had on the phone (keep in mind that i had to manually move them to the SD card) I haven't seen it crash once. But I'll see if I can get a new battery for the phone and report back if it continues.
    09-14-2015 08:10 PM
  5. Cyngn Ray's Avatar
    Hmmm, interesting. I am not a huge fan of moving apps to SD, but I understand that space is an issue with the device. Let me know if you have other issues.
    09-15-2015 02:12 PM
  6. Killescript's Avatar
    Did you tried to change the battey? Try that
    10-09-2015 05:56 PM
  7. miner_films's Avatar
    Sadly, i haven't been able to find a battery that fits my phone. I looked in a few places, but they only seemed to have batteries for completely different models. All of the batteries i saw looked nothing like the battery in my phone, i will keep looking.
    10-12-2015 03:01 AM
  8. Cyngn Ray's Avatar
    Search your specific model on Amazon is my recommendation. I find a lot of good replacements there.
    10-12-2015 10:59 AM
  9. miner_films's Avatar
    Amazon was one of the first places i tried, but it doesn't show any batteries for my phone. And yes i did make the search specifically for my phone and that still turns up batteries that won't work for the phone.
    10-14-2015 05:02 AM
  10. Cyngn Ray's Avatar
    This search on amazon took me 3 seconds. Here is a battery. https://www.amazon.com/Anker-1900mAh...cUvbUpU4749530
    This won't work?
    10-14-2015 03:31 PM
  11. miner_films's Avatar
    How many pages did you have to go through to get that? I went through at least 10 pages and didn't see that amongst the results. From what I can see I think that battery might fit in the spot.
    Where the battery currently sits in:
    Current battery:
    Battery you found:
    10-16-2015 06:37 PM
  12. Cyngn Ray's Avatar
    It literally was the first result for me.
    10-19-2015 01:11 PM
  1. Anyone use a VPN on their phone?
    By dt81 in forum Samsung Galaxy S6 edge+
    Last Post: 09-15-2015, 01:02 PM
  2. Replies: 1
    Last Post: 09-13-2015, 10:49 AM
  3. Replies: 1
    Last Post: 09-13-2015, 10:46 AM
  4. [Q] Samsung SM-G530H get freeze 10-20s in sometimes ?
    By thelastnobita in forum Ask a Question
    Last Post: 09-13-2015, 01:19 AM
  5. Google apps and Facebook not working, how can I get them working?
    By AC Question in forum Google Play Store
    Last Post: 09-13-2015, 01:11 AM
