jpgrb
Okay so I'm totally new here and hopefully I'm posting this in the right place. Here's a summary of my situation:
Keep getting a notification a new version of Pandora is out, so I tried loading the Play Store. It attempts to load, but then force quits. This happened several times. I restarted my device and the same thing kept happening. I cleared the data, chose to force quit it myself and the same thing keeps happening. I even (accidentally) uninstalled my version and had to find another version of Play Store, but it just keeps force quitting on me.
I have an old Samsung Replenish, 3G. The version of Play Store I re-downloaded (from "Android Police"?) is version 4.1.6 (Which oddly enough is taking up more space than the version I accidentally uninstalled. There's also currently no version of "Google Play services" as I long, long, long ago deleted this as it seemed useless and was taking up too much space. However, I don't believe *that* to be the problem, as between then and now I never had a problem updating or adding and deleting other apps.
Um.. not sure of any other info that might be helpful. Thanks so much in advance for any help anyone might be able to offer.
PS: I know the obvious answer is probably update my old, very outdated phone, but unfortunately, that's a last resort at this point as money is very tight.
