1. Chaplainar's Avatar
    I get about 15 spam calls a week, from 3 different numbers.
    I have tried Mr. Number as well as NQ Mobile Manager.
    With the settings to Answer and Hang Up, I still get voicemails, just without the ringing.
    Can anyone recommend a good one for a Gingerbread MyTouch 4g?
    I want no rings, no voicemail.
    04-18-2012 08:31 PM
  2. anon(181017)'s Avatar
    I use Call Filter https://play.google.com/store/apps/d...lFilter2&hl=en
    Seems to have mixed reviews, but works perfectly for me on Droid X with Gingerbread. You can set it to block unknown/private/blocked calls, or block specific numbers. I'm not sure if it sends to voicemail or answers/hangs up right away. Spammers never leave me voicemail anyways...
    06-27-2012 12:23 PM
  3. Irishgator's Avatar
    Google Voice can do this for you. And on Sprint you get integration...
    You can even have those people get the message that your number has been disconnected.
    Sent from my SPH-D710 using Tapatalk 2
    06-27-2012 12:25 PM
  4. Alnn's Avatar
    I use extreme call blocker. Works fine.. But I have noticed if the person tries to call you 4 times in a row (back to back)... They make it through. But for span calls I like the pick up and hang up option. Works every time.
    Sent from my GT-P3113 using Android Central Forums
    06-27-2012 12:30 PM
