1. solo1's Avatar
    The past couple of hours I have been trying to install some FREE apps onto my phone via Appbrain/Webinstall ... I am getting an error message saying that I must ENABLE the websinstall app ... I have enabled it and even did a reboot but it still says error ... I have been using this method for app install for the past couple of days with no issues ... IS anyone else having problems or had the problem and a solution? Thanks
    07-10-2010 01:23 PM
  2. joek1971's Avatar
    does it install if you go to appbrain.com and use it that way
    07-10-2010 01:58 PM
  3. solo1's Avatar
    Im trying to install from the Appbrain website onto my phone ... This is where I get the Error Message
    07-10-2010 02:07 PM
  4. Jerzyiroc's Avatar
    I've never had a problem with Appbrain
    07-10-2010 02:38 PM
  5. solo1's Avatar
    You say NEVER as if this method have been around forever ... I havent had a problem til today ... its gotta be more than just an issue with me ...
    This is what I am getting:
    07-10-2010 03:39 PM
  6. joek1971's Avatar
    try to logout of appBrain on your evo and from the sie also remove it from evo, restart and then reinstall it and try it then.
    07-10-2010 03:47 PM
  7. solo1's Avatar
    Ive logged out and logged back in and still having the same error ... I will unistall the webinstall then re-install it to see if that is the answer next.
    07-10-2010 04:28 PM
  8. meyerweb#CB's Avatar
    I've been unable to update apps today using the regular appbrain app. I think they're having issues of some sort. It's not just you.
    07-10-2010 04:36 PM
  9. solo1's Avatar
    I cant believe that this is a rare issue here .
    07-10-2010 10:50 PM
  10. meyerweb#CB's Avatar
    I ended up solving my problem by rebooting the phone. Have you tried that?
    07-10-2010 11:18 PM
  11. VDub2174's Avatar
    Having the same issue.
    07-11-2010 02:36 AM
  12. jtcarnes's Avatar
    I was having connection issues yesterday while trying to sync my app list and install updates from my phone over good WiFi, so I know it wasn't a connection problem on my end. I haven't played with the web install in a couple of days, but the issues could be related...
    07-11-2010 09:07 AM
  13. melwan's Avatar
    The web install never worked for me since day one. I'm running N1 w/ Froyo and did the setup/enable multiple times.
    07-11-2010 09:13 AM
  14. joek1971's Avatar
    MAke sure you have Fast Web Installer running on EVO I had same problem but I pressed FWI and it all went beack to work.
    07-11-2010 10:00 AM
  15. VDub2174's Avatar
    I have the FWI installed to my EVO but it's still not working
    07-11-2010 11:24 AM
  16. solo1's Avatar
    Ive rebooted my phone and its still a no go with appbrain today.
    07-11-2010 11:35 AM
