1. Leafgreen's Avatar
    After I downloaded froyo on my Evo, only 5 apps appear in the Market Downloads window.However i have over 100 apps installed. Opening the apps or rebooting has no effect. The problem of course is that I can't see updates. Help?
    08-07-2010 06:59 AM
  2. Primetimeplaya's Avatar
    Same thing happened to me. Those that appear are probably apps you paid for. The free apps did appear later though after I powered down the phone and brought it back up.
    08-07-2010 10:29 AM
  3. Cory Streater's Avatar
    Check out the first post of the issues sticky.
    08-07-2010 10:48 AM
  4. Leafgreen's Avatar
    Which is the stickys issue? I do not see it. Please post the link
    08-07-2010 11:29 AM
  5. Cory Streater's Avatar
    Check out item #6 in this thread.
    08-07-2010 12:34 PM
