1. tony bag o donuts's Avatar
    On yet another replacement device.
    However, I can't get this device to sync with appbrain, at least my current list of apps.
    It created a new list, which I deleted and then proceeded to rename the old list to the name given to the new device. No go.
    Ideas?
    08-19-2010 11:44 AM
  2. tony bag o donuts's Avatar
    I helped myself ......
    08-19-2010 11:55 AM
  3. sookster54's Avatar
    LOL how'd you do it? As far as I know when you go to the appbrain website on your PC and is logged in, the list shoudl still be there under "my apps" and you should be able to sync it on your new device, is that what you did?
    08-19-2010 12:55 PM
