I've been trying to use it the past 2 days and when I click on install, it says it's sending the app to the phone, but I get nothing. Anyone else having issues? Suggestions?
If you're new to the installer, you have to run the appbrain app on the phone and it'll sync with the website to fetch what apps you want to install, then you just hit 'run installs' and it'll go.
If you know how to do that and it just isn't working, then I dunno, mine worked fine today /shrug
I have the Fast Web Installer on my phone and it's synced up, but it's not working. When I click on install from the site, it says that it's sending the app to the phone, but it won't do anything.
