1. Primetimeplaya's Avatar
    I have even uninstalled them and they still show on the market as installing. There's no percentage or anything, just installing.
    10-11-2010 08:11 AM
  2. greydarrah's Avatar
    Mine is doing the same thing with 4 installing since yesterday afternoon. Rebooting as well as a battery pull did not help. I'm guessing it's a problem with the market, not your device, and hoping it will clear itself up.
    10-11-2010 08:16 AM
  3. greydarrah's Avatar
    I searched (amazing function) for this and found someone's solution:
    Settings > Applications > Manage Applications > All > Market > Clear Data
    It fixed mine.
    10-11-2010 08:28 AM
  4. takeshi's Avatar
    Also try pressing and holding the pending download/install in the Market app to cancel.
    10-11-2010 08:57 AM
  5. Primetimeplaya's Avatar
    It fixed mine.
    Please remember that how you say things is just as important as what you say.
    Thanks for the info.
    10-11-2010 09:20 AM
  6. Zorro1's Avatar
    I don't like the scary note with the Clear Data...will it remember to auto download? Does it know what I have installed?
    Holding down the downloading file to cancel doesn't do anything, other than for the moment. If it doesn't forceclose.
    10-11-2010 11:14 AM
  7. sniffs's Avatar
    I tried that and it didnt work. I now have a Dell Streak stuck on installing some widget.. tried clear cache/data, and nada..
    10-11-2010 11:30 AM
  8. greydarrah's Avatar
    Are you kidding me? I think the world may be getting a little too hyper sensitive. I was poking fun at myself for not doing my own search on the subject.
    10-11-2010 03:10 PM
  9. greydarrah's Avatar
    All your apps still show up, you just have to click that you agree to the Market terms again. Can't speak to the auto download, as I don't use it, but I would imagine that you can just turn it back on if it gets changed to being off.
    10-11-2010 03:13 PM
  10. Solar One's Avatar
    I have 7 apps that have been downloading for three days now, and have tried most all the solutions given in the above thread with no luck. I can install new apps with no problems. The apps that say they are downloading still work, but it bothers me to go to Market > Menu >, Downloads, and see these 7 with the scrolling green bars every time I look. There may be one more drastic step and that is to uninstall updates:
    Settings > Applications > Manage Applications > [there is no ALL?] Market > Uninstall Updates as I do not want to lose the few updates I have gotten properly.
    Not seeing any replies for a hour or so, I decided to try the "Uninstall Updates" and what it did was uninstall the Market, which was still on my apps screen (in the same location) and then when I launched the Market app I had to re-agree and it loaded back in just fine and it stopped those 7 updates!! It does not remove all updates, just the Market App updates, so all is good now.
    Hope my fustrating experience helps someone else, I love this thing but that crazy constant updating was not right!!
    10-26-2010 02:58 PM
