1. impossiblefunky's Avatar
    Dumb thing - probably a setting that I can't find - but the Marketplace is listed in pounds rather than dollars. Anyone else?
    12-14-2009 03:05 PM
  2. o4liberty's Avatar
    Mine is ok check your time zone in settings it might be set to a European country. I look in market place can't find anywhere to change time zone.
    12-14-2009 03:21 PM
  3. cjohnson481's Avatar
    some devs are not in us, hence the international pricing. google checkout will show you what the us pricing is before you buy.
    12-14-2009 06:01 PM
  4. Roy Aguilera's Avatar
    Exactly. You will see the dollar conversion upon check out.
    12-14-2009 06:29 PM
  5. graymulligan's Avatar
    Wait...you mean everyone, everywhere doesn't use american currency? Freaking tourists...I mean, seriously.
    12-14-2009 11:44 PM
  6. Chris Kerrigan's Avatar
    Not that anyone in Europe would WANT to use the American dollar right now anyway, it's about as valuable as a rat turd.
    12-14-2009 11:54 PM
