1. dkhuizenga's Avatar
    Any one know why i cant use my discover card to buy some apps like titanium backup pro or spegitii and marshmellows, but i can for other apps? The apps say they will take the credit card type.
    Also, why cant i charge some apps to my bill?
    12-25-2010 11:33 PM
  2. Smitty_82's Avatar
    Not sure why your Discover card won't work, might just be the agreement with the devolopers. I use Visa so I have not had that issue. As far as charging to your bill, that depends on the carrier, I think ATT has it but no other carriers support it that I have heard of. It is a new option for ATT.
    12-25-2010 11:39 PM
  3. Chris Kerrigan's Avatar
    T-Mobile also supports this option as well.
    Smitty_82 likes this.
    12-25-2010 11:58 PM
  4. Smitty_82's Avatar
    Thanks Chris.
    12-26-2010 12:05 AM
