Well the issue I was having with my EVO and the market was similar, but not quite the same as reported on the forums. After working fine at first, I could nol longer update my apps. Would get the "unknown reason" error - 18. The error would not happen while installing and it never "hung up" just would get an install failed message.
I had moved all the apps that I could move over to the SD card, but moving them back to phone didnt help. Tried all of the tricks here like clearing the caches and data and taking out and remounting card and nothing worked. Even tried deleting the app and reinstalling it, but that didnt work either. I could download NEW apps, but if it was one I had had on the phone at any point, i would not download. I couldnt even download the paid version of Aldiko after deleting the free version.
So...moved ALL of the apps off the SD card back to the phone and then found could update some but not all of them and, once moved some back (and I need to do that with as many as I have) problem would start again
So something obviously not playing right with the SD card. As I mentioned in another thread, neither IO or Astro would allow me to delete the .andriod_secure file which others have said is the culperate.
What I eventually had to do is isolate the apps that seemed to be causing the problem, for me it was Pulse, Aldiko, and ShopSavy that would not update even after everything was supposidly off the card and would not reinstall even after i had deleted them. So, after I deleted the apps, I unmounted the SD card, then downloaded the apps again with the card out of the phone. THIS time the phone accepted the downloads with no problem and, as I have left them on the phone, the other apps, even ones on the SD card seem to be updating ok.
IT appears then that SOME apps leave some sort of "cookie" (for lack of a better term) on the phone that, once you have put the app on the SD card the downloader looks always to the SD card to do something when you update or try to reinstall -- even if you have put the app back on the phone or deleted it all together. And, if there is some problem with the SD card somewhere, the download/reinstall fails with the error-18. Also looks like a few bad apps can mess up the card for everything.
I am guessing that if i could have deleted the .android_secure file this would have also solved the problem but that just does not seem possible from the Evo anyway.
So, IF you can find which apps are the problem, try deleting and reinstalling them with the sd card out of the phone and then dont put them back on the SD card if that works
In all, quite a pain and hope fixed soon.
