Notification problem
callmecolt
Active member
May 21, 2011
32
Hello,
When I first got my commando, when I would get a new text or e-mail, it would show the red * or something like that next to the icon on my home screen. Not sure if I changed anything by mistake, but now it is not showing it. The only notification it shows is on the bar across the top of the screen.
Did I change something by mistake while I was going threw all the settings? Where do I go to change it back?
Thanks ahead of time! :cool:
I figured out my problem on my own. I had links to the applications, and not the widgets on my home screen.
ryzengames
