1. AC Question's Avatar
    phone will charge, but the car radio does not show an item connected via usb port. this works with apple products.
    04-06-2015 02:37 PM
  2. jdevenberg's Avatar
    Android offers two methods to connect to devices, PTP and MTP. Try switching from whichever you are in now to the other in your settings and see if that works. If not, then your car stereo is likely not Android compatible. Apple uses a proprietary protocol to access media over USB and some manufacturers decide not to support the standard everyone else uses and just build in Apple's version.
  3. JRDroid's Avatar
    04-06-2015 02:54 PM
  1. Native visual voicemail on AT&T?
    By ibuyufo in forum Samsung Galaxy S6
    Last Post: 05-28-2015, 07:23 PM
  2. Replies: 2
    Last Post: 04-09-2015, 09:43 AM
  3. Lock screen widgets on htc m9?
    By Luis Arce1 in forum HTC One M9
    Last Post: 04-09-2015, 09:33 AM
  4. Recommendation on a antivirus?
    By robert7107 in forum Android Apps
    Last Post: 04-06-2015, 01:32 PM
