1. Poolmand's Avatar
    Dear all.
    I have asus padfone 2 infinity moblie.
    Recently i have issue with battery percentage. When I charged phone to 99% then restart phone it show me 1% battery and it work a long time with 1% charge.
    Some times i restart phone with plugged charger to it it shows me 99% battery after restart.
    Some times it shows me 1% but not charge more with charger.
    What is the problem and how can i solve it?
    My Android is 5.0.2 and my device is not rooted.
    05-30-2017 04:39 AM
  2. pkcable's Avatar
    I found this battery calibration guide at XDA which might help.
    https://forum.xda-developers.com/and...evice-t3308554
    05-30-2017 08:04 AM
  3. Poolmand's Avatar
    Thank you.
    I read it but i can not do it because:
    1.when i plugged charger to phone when my phone is off the phone automatically turned on.
    2.when i charged phone to 100% when i restart it then shows me 1% i do it more and more
    05-30-2017 08:57 AM
  4. pkcable's Avatar
    Perhaps a factory reset is in order? BUT let me reach out for more help.
    05-30-2017 09:13 AM
  5. Poolmand's Avatar
    reset factory disn`t solved anything.
    recently I charged phone to 99% then I restart it and now it show me 1% again. I installed "battery waster" application to drain battery and with all sensore ON, torch on, 8 core CPU work , ... for more than 30 MIn my ohone is ON and battery is 1% yet
    05-30-2017 09:22 AM
  6. pkcable's Avatar
    Maybe there is actually something physically wrong with the battery? Are you under warranty? Or if not maybe you got lucky and there is a recall? Have you checked with Asus? They are a pretty solid company.
    US - https://www.asus.com/us/support/
    Global - https://www.asus.com/support
    05-30-2017 09:28 AM
  1. Galaxy s7. Audioserver massive battery drain
    By Blacksoul178 in forum Samsung Galaxy S7
    Last Post: 07-05-2017, 05:45 AM
  2. Wireless charging issues
    By I_didnt_do_it in forum Samsung Galaxy S6 edge
    Last Post: 06-09-2017, 12:56 AM
  3. Replies: 6
    Last Post: 05-30-2017, 11:03 AM
  4. Replies: 1
    Last Post: 05-29-2017, 05:09 PM
  5. Samsung Note 4 issues
    Last Post: 05-29-2017, 09:32 AM
