I just got Power Rangers Legacy and Drag n’ Boom across on my MatePad Pro from APKPure and they work no problem. These were definitely my top games on my iPad so I’m glad they’re working, what’s everyone else playing on New Huawei’s with no Google?
Is there any difference between the versions of games available on APKpure and Play Store? Still on the fence in regards to Huawei devices without google.
Howdy! I expanded your title to be more expressive of your post's intent, and hope it helps you connect with others in the same situation. Glad you're able to play what you enjoy!
Love a simple game myself, can't go wrong with solitaire ha!
I'd like to find out too, like if you dl the app, will it update normally? I play Hearthstone (card game) on my phone mostly, and it used to be that you would dl the apk from Blizzard's site (developer/publisher) and they would update it themselves. But they did move to the play store at some point and it would be updated through there. Can you get the apk?
No, no difference at all from what I can tell. Only thing I would say is that if you Phone Clone a game over it may not work sometimes.
My mate did this with COD the other day, it updated and then didn’t work cos it was looking for Google Play Store to download the addition data from, so you need to install the xapk version
I just went through APKPure then and I think it seems to install ok. Give it another try mate.
