1. The General52's Avatar
    So I'm yet to jump on the P40 Pro but am getting closer to making the decision. Its a big move for me because I love Huawei devices but not having GMS slightly throws me off.
    Having seen everyone talk about how easy it is to get all their apps. I've noticed one way is using Phone Clone.
    So if I use phone Clone to transfer all my apps, how do some of those apps get updated later on?
    I know if its through app gallery they will update as normal
    Thanks
    06-22-2020 04:47 AM
  2. garlow's Avatar
    Like you said if done through app gallery thats as normal but if you do it through another source personally I'd recommend petal search
    A) its the easiest way to search different sources for apps
    B) it'll inform you when you need to update certain apps you download this way as they wont auto update I believe
    06-22-2020 06:27 AM
  3. The General52's Avatar
    So through Petal Search, ill get the notification that there's a new version but will have to manually update?
    Not too bad, thanks
    06-22-2020 06:38 AM
  4. OnkenEater313's Avatar
    Ive seen a few updates flashing up in Petal Search but it looks like this still needs some fine tuning. Ive found the easiest way is to have APK Pure installed then the updates flash up there, you still need to click the Install button when it finishes downloading so its not the smoothest experience just yet but its not bad at all
    06-23-2020 10:30 AM
  5. wakawaka89's Avatar
    Hello, I got a majority of my apps through phone clone
    06-23-2020 11:10 AM
  6. wakawaka89's Avatar
    The rest through petal search I don't know if its been updating them in the back ground?!
    Have you found APK Pure to be adequate?
    06-23-2020 11:11 AM
  7. SamRH1's Avatar
    Apk pure seems to be fine when i've used it in different devices in the past. I think some apps update automatically but not all so if you are worries about an update go back into Apk pure and searc for the app you want to update and update manually.
    To be honest with you though most update anyway i've never had to do a manual update.
    06-24-2020 02:52 AM
  8. The General52's Avatar
    So you're saying have apk pure installed separately?
    06-24-2020 03:27 AM
  9. The General52's Avatar
    I don't actually have the P40 Pro yet but I will be upgrading soon so I'm doing my utmost to understand everything before I commit to purchase
    06-24-2020 03:28 AM
  10. wakawaka89's Avatar
    Ahh sorry!! You wont be disappointed!!!
    06-24-2020 03:38 AM
  11. wakawaka89's Avatar
    which one are you mainly using petal search or APK pure?
    06-24-2020 03:39 AM
  12. garlow's Avatar
    Oo I didnt know this, ill have to do that thanks!
    06-24-2020 03:44 AM
  13. OnkenEater313's Avatar
    I use Petal Search to find the Apps cos I think it's the most reliable way of knowing they'll work. Sometimes I find an App isn't in Petal Search so I go to APKPure and it works but not always.
    06-24-2020 04:01 AM
  14. OnkenEater313's Avatar
    It looks like Petal Search doesn't yet do a great job of updating Apps so that's why I go into APKPure. Tap the dots in the top right and it shows the Apps needing updates. Just go to APKPure website and it lets you download their store
    xTlex likes this.
    06-24-2020 04:03 AM
  15. wakawaka89's Avatar
    ive just checked my updates on petal search and its telling me I need to update my google keyboard!! I guess it came over with phone clone!! Get out of my phone google you are not welcome!
    06-24-2020 04:26 AM
  16. xTlex's Avatar
    I'm glad I looked for more posts like mine, I am also looking to potentially get the P40PRo (plus would be too big for my hands). Tonnes of good info in here, especially around Petal Search, how does it work exactly? Is it just another app?
    06-24-2020 05:12 AM
  17. wakawaka89's Avatar
    I just downloaded it from the app gallery and it can sit as an app or a wisdget, ive put it on as a widget cus it looks cool. Haha
    xTlex likes this.
    06-25-2020 03:15 AM
  18. garlow's Avatar
    I believe it comes preinstalled now on phones?
    06-25-2020 03:30 AM
  19. wakawaka89's Avatar
    Does it? That's good if it does!1
    06-25-2020 03:35 AM
  20. The General52's Avatar
    That's good to know then, ill make note of this because ill surely forget. I hope Huawei makes the process easier in the future
    06-25-2020 04:14 AM
  21. xTlex's Avatar
    I just realised I could just download it from Huawei's app store onto my P20 Pro as well (no idea why it didn't dawn on me earlier). I searched a few things and seems like they got a lot of stuff, they are searching all kinds of apps stores and apk sources including straight to sources (like Whatsapp, etc).
    06-25-2020 05:09 AM
  22. garlow's Avatar
    I'm sure as time goes on the apps will just be made for Huaweis app store
    06-26-2020 03:52 AM
  1. Unlocked phone on Verizon confusion/questions.
    By acraftylady in forum General Carrier Discussion
    Last Post: 06-29-2020, 11:11 AM
  2. Hearing a random iOS sound on Android S9?
    Last Post: 06-22-2020, 03:43 AM
  3. Unlocked phone on Verizon confusion.
    By acraftylady in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 06-22-2020, 03:14 AM
  4. Direct share isn't working on my Moto Edge+.
    By sicario666 in forum Moto Edge+
    Last Post: 06-22-2020, 02:25 AM
