1. Avatar_08's Avatar
    it just shows that is charging for a second then stops no more flashing and it has completely shut i can`t do anything
    08-05-2019 11:36 AM
  2. Rukbat's Avatar
    With a microUSB connector, the first place I'd look (if I had your phone to repair - this is not a do it yourself project) would be the microUSB connector. One of the power pins (there are two for power, two for connecting to a PC) is unsoldered, and just close enough to the hole that, as you push the connector in, it makes contact for a moment. (Don't wiggle it around to check - the little sparks you cause can destroy that tiny portion of the motherboard, requiring a whole motherboard replacement.)
    Bring it into a repair shop.
    I assume that you've already tried another charger and another cable. (They're interchangeable - if a friend has a charger with a microUSB connector [not a Type C connector, which is oval, it doesn't have one side larger than the other], try it. If it works, it's your cable or your charger. Use your cable and his charger. If it works, it's your charger, if it doesn't, use his cable and your charger - that will work, you just need a new charging cable.)
    08-05-2019 04:34 PM
  3. B. Diddy's Avatar
    I moved this from the Jellybean forum to the More Huawei Phones forum, because a 2019 phone clearly is not on Jellybean.
    08-16-2019 02:43 AM
  1. Seriously thinking of switching to Huawei p30 pro from Galaxy S10
    By shoaib shah in forum Huawei P30 & P30 Pro
    Last Post: 08-12-2019, 08:19 AM
  2. Why line shows what typing disappeared.
    Last Post: 08-08-2019, 12:19 AM
  3. Why cant stall my messenger
    Last Post: 08-05-2019, 04:09 PM
  4. Replies: 11
    Last Post: 08-05-2019, 12:00 PM
  5. Why does my phone say I'm offline when I try to use any internet needed apps?
    Last Post: 08-05-2019, 05:54 AM
