Lg tribute hd boost mobile
charles3526
3
Hello i am using this phone for about a month now i like it. My question is can i some how get this phone to move apps to sd card? I am on android 6.0.1 idk if that's marshmallow or not. Any help would-be great
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,517
4,659
113
Welcome to Android Central! Not all devices support the ability to move apps to SD. If you don't see a Move to SD button anywhere in the Settings>Apps menu (after selecting an app), then it's not supported. You'd have to root the phone and use an app like Link2SD or App Mgr III.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,517
4,659
113
It depends on how important it is for you to have apps on the SD. Be aware that apps installed on SD often don't perform as well, since the SD read/write speeds will be slower than onboard memory. In addition, cards get corrupted, so if something happens to the card, your apps may crash, with possible data loss.
Debiec68
10
My last phone was LG TRIBUTE HD. To move apps to SD (if app allows) go to STORAGE. And up above the DATA and CACHE, you'll see another clickable box that says CHANGE.
Everyone Has to change what's not broken, so instead of using the word MOVE, they chose the word CHANGE.
click that, and another screen opens asking to Confirm.
Debiec68
10
muejnkfabet
