1. I need k8 help's Avatar
    I have a k8V that i tend to use on the charger a lot. The battery dies extremely fast even though it's supposed to have 16 hours of usage time. The generic ways like airplane mode, brightness, and clearing the apps do nothing. And battery savers don't either. Please help. I also have no money to get a new battery or a repair.
    10-15-2017 06:29 PM
  2. B. Diddy's Avatar
    Moved from the Accessories forum to the More LG Phones forum.
    How old is the phone? If it's more than a year old, and if you use the phone pretty heavily, the battery might be starting to deteriorate (or the battery might just be defective).
    To get an idea of what's causing the drain, it would help to see some stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    10-15-2017 10:57 PM
  3. I need k8 help's Avatar
    I got it in april i think
    10-16-2017 06:45 AM
  4. I need k8 help's Avatar
    Also I switch out the battery since it's a replaceable
    10-25-2017 09:25 AM
  1. How good are the official Clear and Silicone Cover?
    By dlalonde in forum Samsung Galaxy S8 & S8+
    Last Post: 10-25-2017, 08:13 AM
  2. Unable to get Apps on moto G5
    By Android Central Question in forum Moto G
    Last Post: 10-15-2017, 11:08 PM
  3. How do i get emojis on my moto g4 plus
    Last Post: 10-15-2017, 06:43 PM
  4. Can't get my phone back to color
    Last Post: 10-15-2017, 06:32 PM
  5. how to get past an abnormal factory reset samsung account sign in?
    Last Post: 10-15-2017, 04:21 PM
