1. AC Question's Avatar
    Everytime I turn on my Samsung It always in Airplane mode. I tried to turn off the Airplane mode, but after a few seconds its Airplane mode again. How can I Fix it?
    02-25-2016 10:19 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen in Safe Mode? https://support.t-mobile.com/docs/DOC-11724. The steps for the S4 ought to work for the Ace 4.
    02-25-2016 11:54 AM
  3. boszlexpii28's Avatar
    Does'nt work sir. :3 still stuck on airplane mode.
    02-25-2016 12:44 PM
  4. boszlexpii28's Avatar
    My main probLem is when I turn on my Samsung ace 4 I have a sim network, but after a few seconds its automatically activated the air plane mode and shown a pop up (PLEASE INSERT CORRECT SIM) at the center of the screen. Please help sir.
    02-25-2016 12:55 PM
  5. B. Diddy's Avatar
    Ask your carrier for a replacement SIM.
    02-25-2016 03:02 PM
  6. boszlexpii28's Avatar
    But if, I insert the main/original sim there's no pop up shown and not stuck on airplane mode? When I insert my own sim, my phone can recieved text/call but after a few seconds that's it. Automatically activate the airplane mode and shown the pop up. I dont think so If the IMEI is the probLem in my sim network or the airplane mode stucking?
    02-25-2016 10:31 PM
  7. B. Diddy's Avatar
    What's the difference between the original SIM and yours? If only your SIM is doing this, while the original SIM works fine, that's even more evidence to suspect that your SIM card is faulty. If the original SIM is not for your carrier or account, then contact your carrier and ask to replace your own SIM.
    02-26-2016 10:07 PM
  1. Replies: 3
    Last Post: 02-25-2016, 06:12 PM
  2. Replies: 1
    Last Post: 02-25-2016, 12:07 PM
  3. Lock Booster app is not getting uninstalled
    Last Post: 02-25-2016, 12:06 PM
  4. How to reset voicemail password on s6 active
    Last Post: 02-25-2016, 12:03 PM
  5. Replies: 1
    Last Post: 02-25-2016, 11:57 AM
