1. AC Question's Avatar
    Can anyone tell me if the SS Galaxy 3 mini's battery or any other SS battery model would be able to work/fit with a SS Galaxy Express 2? The phone is also labeled as the Samsung G-3815. I'm able to order it via ebay but it will be quite costly, so I'm trying to source it locally. Problem is that I can't find that particular battery model. I know that the Galaxy Express 2 battery can also fit in other SS phone models.
    Thanks
    05-15-2017 06:43 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It doesn't look like the S3 mini's battery is compatible. The images show that they have different dimensions and configurations:
    https://www.amazon.com/Samsung-Galax...cUvbUpU5815539
    2200mAh Replacement Battery for Samsung Galaxy Express 2 G3815 G3818 G3819 G3812
    That eBay listing says that the battery for the Express 2 is also used in the Galaxy Win Pro, so you could try searching for that model.
    05-15-2017 11:50 AM
  1. Epson Printer Issue with Galaxy S3
    By Beckie0915 in forum Samsung Galaxy S3
    Last Post: 05-22-2017, 08:06 AM
  2. yahoo email problems on galaxy s3
    By AC Question in forum Samsung Galaxy S3
    Last Post: 05-17-2017, 09:50 PM
  3. Charging Comparison for OnePlus 3T
    By AC Question in forum OnePlus 3 & 3T
    Last Post: 05-15-2017, 05:13 PM
