    I have galaxy grand prime sm G530H the probelm is whenever i tried to install firmware which i have downloaded from samsung site through Odin i got below mentioned error, i changed laptop, usb cable, redownload the firmware but nothing goes in my favour, can someone please help me?
    <ID:1/008> Added!!
    <ID:0/009> Odin engine v(ID:3.1207)..
    <ID:1/008> Odin engine v(ID:3.1207)..
    <ID:0/009> File analysis..
    <ID:1/008> File analysis..
    <ID:0/009> SetupConnection..
    <ID:1/008> SetupConnection..
    <ID:1/008> Initialzation..
    <ID:1/008> Get PIT for mapping..
    <ID:1/008> Firmware update start..
    <ID:1/008> NAND Write Start!!
    <ID:1/008> SingleDownload.
    <ID:1/008> aboot.mbn
    <ID:1/008> FAIL! (Auth)
    <ID:1/008>
    <ID:1/008> Complete(Write) operation failed.
    09-09-2018 04:33 AM
  2. Rukbat's Avatar
    If it can't even write aboot, you may have bad storage. (And since that's on the motherboard, you;d need a new motherboard.)
    09-09-2018 01:12 PM
  1. How do I fix dns address can’t be found error when searching internet?
    Last Post: 09-09-2018, 01:51 PM
  2. Download unexpected issue
    By Android Central Question in forum Software Development and Hacking
    Last Post: 09-09-2018, 01:22 PM
  3. The calculator app that can draw over other apps. I need help.
    By BabyGirlCarter73 in forum Ask a Question
    Last Post: 09-09-2018, 03:41 AM
  4. Download unexpected issue
    Last Post: 09-09-2018, 02:58 AM
  5. The calculator app that can draw over other apps. I need help.
    Last Post: 09-09-2018, 02:49 AM
