1. Caleb Rodgers's Avatar
    I was wandering if there is a way to change the volume of incoming call rings and notifications on the headphones and not the handset's loudspeaker. Still running stock Android lollipop, but the phone is rooted. If this can't be done with stock Android then could it be done with CyanogenMod or an app.
    if I'm going to use CyanogenMod I will have to have a lot of little things it can do that I would actually use. I just got this phone and I'm not sure what Samsung features I will miss from the Galaxy exhilarate. if I end up only needing two or three things that apps can do I won't use CyanogenMod.
    Either way, I need to do something so I don't blow my ears out when listening to music and somebody calls. Thanks in advance for any help you can offer.
    07-15-2015 06:18 PM
  2. Caleb Rodgers's Avatar
    I found an app, but it's not separate. Any other apps or settings you know of.
    07-19-2015 11:42 PM
  3. Caleb Rodgers's Avatar
    I hope I am not breaking the bumping rules.
    07-27-2015 01:05 AM
  4. Caleb Rodgers's Avatar
    Bump.
    09-29-2015 12:47 PM
  1. Call quality is bad
    By flackberry in forum Motorola Droid Turbo
    Last Post: 07-16-2015, 11:58 AM
  2. just bought a tech21 and checked out mighty shell
    By Blues Fan in forum Samsung Galaxy S6
    Last Post: 07-16-2015, 12:40 AM
  3. Replies: 1
    Last Post: 07-15-2015, 06:35 PM
  4. How do I add words into the dictionary of my Galaxy Core Prime?
    By AC Question in forum Samsung Galaxy Core
    Last Post: 07-15-2015, 05:15 PM
  5. Replies: 0
    Last Post: 07-15-2015, 04:38 PM
