The sound it glitches.Welcome to Android Central! It'd be helpful to hear more details about the issue.
Google play music and mx player. It's locally stored music on the internal memory. I'm using wired headphones.What app are you using? Is this locally saved music or streaming? If it's locally saved, is it on Internal Storage or the SD card? Does the sound glitch over wired or Bluetooth headphones as well?
Yes all music but more heavy files are more affected. And also the glitches is not always it's irregular but usually starts after 5 minutes in standby. I haven't tested if it affects the speaker since I'm always using the headset inside and outside.Does it glitch for all music, or only certain files? Does it glitch over the main speaker as well?
No I didn't perform any of the things you mentioned.Does this happen in Safe Mode? Or after a cache partition wipe? MOTOROLA Moto E4 - Recovery Mode - HardReset.info
