1. mobrules's Avatar
    Anyone know why this would happen? On a restart from completely off it goes to the screen to select recovery/tools/clear cache. It's the first screen with the Android mascot on its side and door open to inside.
    Maybe I'm not describing it correctly. But I'm sure you know what screen I'm describing.
    Have no other problems with the phone, it works great! It's a family members phone. Don't know how long it's been doing it or why.
    12-30-2017 02:33 PM
  2. YAYTech's Avatar
    Is it able to then select a normal startup & start correctly?
    01-01-2018 10:31 AM
  3. mobrules's Avatar
    Yes it will start normally. But if it's shut down it goes to that everytime. My worry is my father in-law is not technologically proficient and I can almost guarantee he will choose the wrong selection one day and then I'm driving 50 miles to restart his phone. Not an over exaggeration, I've had to do it.
    01-01-2018 02:43 PM
  4. mobrules's Avatar
    Bump...... Hoping to get a few ideas on this.
    01-03-2018 11:30 PM
  1. Battery started draining fast, new battery same issue
    Last Post: 12-30-2017, 12:29 PM
  2. I need to reset a galaxy tab.
    Last Post: 12-30-2017, 12:17 PM
  3. Rception issues
    By stuarta99 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 12-30-2017, 10:26 AM
  4. New Huawei P10 plus UK unlocked- how long for updates?
    By Android Central Question in forum Huawei P10 & P10 Plus
    Last Post: 12-30-2017, 10:10 AM
  5. New Huawei P10 plus UK unlocked- how long for updates?
    Last Post: 12-30-2017, 09:14 AM
