1. ParadoxChils's Avatar
    During a call, the screen turns off when near my face however if the screen touches my face inputs still happen so it ends calls despite the screen being off. Is there a fix for this or is it a return the phone job? Thanks in advance.
    01-15-2018 06:10 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! When you make a call, hold your finger or hand over the proximity sensor (right near the front-facing camera) -- does the screen turn completely black, or can you see the screen faintly?
    Does this also happen in Safe Mode? Using Safe Mode on the Moto E (4th Gen Plus)
    01-15-2018 06:53 PM
  3. ParadoxChils's Avatar
    I'm really sorry - I didn't know this reply came through and I forgot my login details...
    The screen goes completely black. I've booted into Safe Mode, done factory resets etc but it remains a problem. Its a pain because it mutes my mic or ends the call and I have no idea it's happening as the phone screen is black.
    Thanks for your help and sorry its been so long!
    03-01-2018 05:25 PM
  4. B. Diddy's Avatar
    Ok, try this then -- cover the proximity sensor with your hand or finger while on a call, then try tapping the screen at random -- does it register button presses even with the screen completely black?
    03-01-2018 11:49 PM
  5. Sana Fakhar's Avatar
    Sir in my Moto e4 there is calling problem issue.no incoming and outgoing calls
    05-14-2018 10:59 PM
  1. Why can't I hear people on incoming calls when my phone is in silent mode?
    Last Post: 01-15-2018, 07:14 PM
  2. I have a problem with my LG phone and music playing apps.
    By bittermelon in forum Android Apps
    Last Post: 01-15-2018, 06:12 PM
  3. when I try to make a call
    By steamerdave in forum Ask a Question
    Last Post: 01-15-2018, 03:45 PM
  4. n not call out
    Last Post: 01-15-2018, 03:39 PM
  5. How can i set a ringtone for private calls
    Last Post: 01-15-2018, 02:00 PM
