1. AC Question's Avatar
    I bought Moto G 2nd Gen. 2 weeks ago and immediately updated it to Lollipop and i get low battery performance and i don't even play games on it or play videos..just basic stuff(calling, google, whatsapp) nothing more. But today my battery dropped from 92% to 52% in about 20 min after i charged i for 1 hour in morning and then from 52% to 1% in 2 min but it didn't shut down so to check i played some videos on youtube and then i restarted my phone and then it show that i have 75% battery.. So is it a software problem or hardware problem? Do i have to change my phone? What should i do?(And sorry for my english it's no very good)
    04-02-2015 04:55 AM
  2. itguyjax8430's Avatar
    Sounds like the OS Is a little buggy. Try booting in to recovery and clearing your cache partition. If that does not work then a factory reset will probably do the trick. There has been a lot of issues with the Lollipop update on phones.
    1. Power off device
    2. Press Volume DOWN + Power buttons for 3 to 5 sec then release Volume DOWN and then Power
    3. Now select Recovery. Android with /!\ will be shown.
    [Lollipop]
    4. Press Power and while pressing it tap Volume Up
    04-02-2015 10:01 AM
  3. isdaako's Avatar
    The false battery reading has happened a couple times on my 2014. Did a cache cleaning and it has not returned.
    04-02-2015 06:29 PM
  1. Replies: 6
    Last Post: 04-30-2015, 09:48 PM
  2. Nexus 7 2013 (Battery Issue) on lollipop
    By DudeItsSheen in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-15-2015, 09:38 PM
  3. How do I read an old saved text message on a pc?
    By AC Question in forum HTC Amaze 4G
    Last Post: 04-02-2015, 09:22 AM
  4. Replies: 0
    Last Post: 04-02-2015, 03:05 AM
  5. What is the hyperion battery (MHZ) of Galaxy Beam i8530?
    By AC Question in forum Samsung Galaxy Beam
    Last Post: 04-02-2015, 01:06 AM
