1. zrxoa1's Avatar
    Is it possible to add the numeric battery percentage to the top of the screen?
    09-18-2015 03:24 PM
  2. Javier P's Avatar
    Take a look at this thread for some ideas.
    http://forums.androidcentral.com/sho...d.php?t=582490
    How can I display the battery percentage in the notification bar on my Moto X Pure Edition?
    09-18-2015 03:33 PM
  3. acejavelin's Avatar
    It should show up automatically well charging on the lock screen, otherwise...
    https://play.google.com/store/apps/d...oid4batpercent\
    This will enable a small %% number inside the battery icon when NOT charging, it maybe sufficient and is easy and unintrusive or use an app like GSAM and get any number of icons in the notification bar or in the notification pull down
    Attached Thumbnails How to get battery percentage next to battery icon?-homescreen.png   How to get battery percentage next to battery icon?-homescreennotifshade.png
    09-19-2015 08:09 AM
  4. officially_juju's Avatar
    I use the Percent Enabler app. Works flawlessly 👍
    Attached Thumbnails How to get battery percentage next to battery icon?-19818.jpg
    09-21-2015 12:57 AM
  5. zrxoa1's Avatar
    Nice n simple. I like it!
    09-21-2015 02:12 AM
  6. bafare's Avatar
    I don't think that's a deal breaker cause I just double finger slide down to check battery percentage.
    Posted via the Android Central App on Moto X 2014/Moto G3/Moto G1/Lenovo Tab S8/ Lenovo Yoga 11
    09-23-2015 04:15 PM
  7. Sizzers's Avatar
    Also have a look at Battery Notifier BT.
    I have the Pro (paid) version but the free version has what you're looking for as in my screenshot (the colour is customisable), although you cant actually place the percentage next to the battery. Has a great set of other functions as well and worth checking out.
    Attached Thumbnails How to get battery percentage next to battery icon?-1443165689069.jpg
    09-25-2015 02:21 AM
  1. How do you inlock a Galaxy S4 phone stuck in kid mode?
    Last Post: 09-19-2015, 01:26 AM
  2. How do I access my favorites list in Google on my note 5???
    Last Post: 09-19-2015, 01:25 AM
  3. Can't transfer apps to micro sd card
    By Mustafa Tuysuz in forum General Help and How To
    Last Post: 09-19-2015, 01:24 AM
  4. How can I get move files from internal storage to sd card?
    By AC Question in forum ASUS Padfone X
    Last Post: 09-18-2015, 05:39 PM
  5. "App blocking access to keyboard" error message.
    By gmermel in forum General Help and How To
    Last Post: 09-18-2015, 03:14 PM
