1. audiospeaker2001's Avatar
    Hello , My name is Sandro , and I have a problem with my MotoG 3rd Gen.
    I bought it last month, and he with two weeks of use, malfunctioned on display and had to be sent to technical assistance for three weeks , he returned for seven days , and three days ago he had a problem in speakers , they do not work only for connections . I can not hear audio from whatsapp , music or games. only with headphones.
    I wonder some solution , because I can not be without cell phone, use it for work.
    Already, grateful
    Sandro .
    P.S. I'm brazilian, sorry for the mistakes on the text.
    09-29-2015 10:28 AM
  2. Javier P's Avatar
    Hello Sandro, bem vindo à Android Central!
    Being a new phone I would try getting a replacement since it's still under warranty. It's not normal having so many problems in the first month. Can you do that easily? Did you buy it from a "operadora" or unlocked?
    PS. Não se preocupe, seu inglês está muito bem
    09-29-2015 10:42 AM
  3. audiospeaker2001's Avatar
    Oh, Hello !
    No .. Unfortunately I can not change , the time to give in Brazil is 7 days after purchase; (
    I believe it is a software problem ..
    I bought it unlocked, and I wonder if is to do my audio work again
    PS: Mito obrigado pelo elogio
    09-29-2015 10:53 AM
  4. Javier P's Avatar
    That 7 days period applies if you return the phone to the shop you bought it. You need to take it to an official Motorola service, or contact them through chat or email after that.
    I'm not sure if that's a software problem. You can always try wiping the cache partition and see if it helps.
    09-29-2015 01:14 PM
  5. sr_enzo's Avatar
    I am here just to bump the thread. Have been going through the same issue.
    10-14-2015 06:14 PM
  6. Vishwas00's Avatar
    just shaked the phone to switch on and off the torch, and now its working.
    Saritesh Tiwari likes this.
    06-14-2016 04:39 AM
  7. Saritesh Tiwari's Avatar
    I also just shaked the phone 7-8 times and after 15 or 20 secondsthe speaker started working.
    11-16-2016 09:06 AM
  8. ASHOK SAH's Avatar
    I also shaked my phone 7-8 times where the speaker is located and voila ! it started working
    12-09-2016 02:12 AM
  9. Vinothkumar Arputharaj's Avatar
    I Shaked my phone that switched on flash light. Then Shaked to switch the light off. Repeated the processor for 5 times.
    Hurrayyyy!!! Speaker started working. Thanks for the suggestions by others users.
    Already, grateful
    Sandro .
    02-19-2017 01:10 AM
  10. acidxeno's Avatar
    Worked for me, smacked it a few times from different sides and it started working. Keep audio playing in background to hear when it starts working. Thanks
    04-19-2017 07:13 PM
  1. Help with Sunshine and using FoxFi after OTA on Droid Ultra
    By UpNorthSurf in forum Droid Ultra Rooting, ROMs, & Hacks
    Last Post: 10-13-2015, 03:21 AM
  2. Google Account Problem
    By MaxDaBoss23 in forum Ask a Question
    Last Post: 09-29-2015, 10:46 AM
  3. Help Viewing Android Backup files on PC
    Last Post: 09-29-2015, 07:59 AM
  4. My HTC DESIRE 601 is stuck in FASTBOOT, please help.
    By Tsakadze1 in forum General Help and How To
    Last Post: 09-29-2015, 07:50 AM
  5. Help with Sunshine on Moto Droid Ultra for FoxFi
    Last Post: 09-29-2015, 06:49 AM
