1. AC Question's Avatar
    Don't know what is happening but since last 3-4 days when i got incoming call, phone is just ringing but not showing call on display screen. but when someone massage me or whatsapp me notification is popup and show that message..
    Looking a reply for this issue.
    01-08-2016 02:25 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this persist after a reboot? If so, try wiping the cache partition: https://motorola-global-portal.custh.../clear%20cache
    Mayur Dahale likes this.
    01-08-2016 03:26 AM
  3. acejavelin's Avatar
    Reboot... wipe cache partition... you can also try this, go to Settings - Apps - Show System Apps (in Lollipop swipe to All) and find Phone, Phone Call Management, and Phone Services, and clear cache and data on those three apps and reboot. Note do NOT clear data on the app called Phone and Messaging Storage, you will lose your contacts and SMS messages.
    B. Diddy likes this.
    01-08-2016 10:21 AM
  4. NucleBAH's Avatar
    If your screen is on and being used you will only get a Heads Up Notification and a ringtone, however if you don't get that all I can say is do the following in order:
    1) reboot
    2) see if it works
    3) clear cache in recovery
    4) see if it works
    5) factory reset
    6) see if it works
    If it works after any of those steps stop there.
    01-08-2016 05:21 PM
  5. Mayur Dahale's Avatar
    Thank you this solved the the problem in my Droid Turbo.. Now screen comes up when incoming calls...
    11-13-2016 05:23 AM
  6. Vijay Kumar P1's Avatar
    I am facing same problem. May I know which solution worked for you?
    Reboot? OR wiping cache partition?
    09-01-2017 10:10 AM
  7. kiliman13's Avatar
    Maybe your phone app. notifications are on BLOCK mode.
    Just navigate to Phone App in, Setting>Apps(All Apps)>Phone>Notifications, and turn off the Block all option.
    10-03-2017 03:48 PM
  8. somecraziness's Avatar
    Same problem - this worked for me. Notifications were on block mode for some reason. Thanks!
    11-13-2017 11:57 AM
  9. Dr K V Siva Prasad's Avatar
    I also faced this problem for Moto X Play. No display during incoming calls. Only ring tone is heard and to answer the call was a difficult process. Reset App preferences didn't work. Here is the solution:-
    Go to settings ~ Apps ~ Phone ~ Notifications~ turn off 'Show silently'. No need to uninstall any app.
    12-24-2017 08:39 AM
  10. Laxmi Kant Mishra's Avatar
    Thank you
    All notifications from the app "Phone" were blocked somehow.
    Probably my brother long pressed the incoming call in notification window and touched on block all notifications.
    04-14-2019 08:37 PM
  11. punit bhojwani's Avatar
    Cleared cache partition checked notification but not yet solved
    Downloaded drupe app after that upto 90 % problem solved of incoming still when calling someone it takes time i think company needs to update the app
    05-07-2019 07:48 AM
  1. Why is my Galaxy S5 unresponsive after decryption?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-28-2016, 11:42 AM
  2. I got a Code in my Doze!
    By Hawgee in forum Nexus 6P
    Last Post: 01-08-2016, 02:03 PM
  3. Why can't I use my google play store credits?
    Last Post: 01-08-2016, 03:41 AM
  4. can i make my mxq streaming box private
    Last Post: 01-08-2016, 03:39 AM
  5. Date keeps turning itself on on my ZTE phone, how can I stop this?
    By scott maly in forum Other ZTE Android Phones
    Last Post: 01-08-2016, 03:30 AM
