1. AC Question's Avatar
    hi all i have a Moto G3 (XT1541)...
    I would like to able to customise the quick menu settings....but i cannot seem to enable the UI System Tuner.... I've pressed the cog many many times at varying length but nothing happens?
    can anyone help? please??
    02-17-2016 11:50 AM
  2. Javier P's Avatar
    Hi, welcome to the forums! Do you have the developers options enabled in your phone? If so, make sure that the animations are not switched off. Set the three values to 0.5x or 1x and restart the phone. Tell us how it goes.
    02-17-2016 12:18 PM
  3. acejavelin's Avatar
    Use 2 fingers to pull the notification slider down, then long press the Settings Gear button in the upper, right corner for about 8-10 seconds... It's not a multi-tab enable like Dev Options.
    02-17-2016 06:24 PM
  1. Replies: 2
    Last Post: 10-29-2016, 01:13 PM
  2. Why can't I see incoming sms messages?
    By AC Question in forum Samsung Galaxy S4 Mini
    Last Post: 02-17-2016, 12:46 PM
  3. Replies: 0
    Last Post: 02-17-2016, 11:32 AM
  4. texting between android and iphone
    Last Post: 02-17-2016, 11:01 AM
  5. Replies: 0
    Last Post: 02-17-2016, 11:00 AM
