1. Roger David's Avatar
    Is phone reset is best way to fox any problem
    05-05-2016 03:53 AM
  2. Javier P's Avatar
    Well, that depends on the problem. Most of them can be fixed with less radical procedures.
    acejavelin likes this.
    05-05-2016 04:20 AM
  3. acejavelin's Avatar
    No, not the "best way"... sometimes it is the only way, but many times it is a last resort, it all depends on the problem. The key is a factory reset takes you back to a known good state (provided you didn't mess around with root access in the wrong place) when nothing else works, that is often a good point to get to.
    05-05-2016 10:50 PM
  1. Where is the memory hog
    By pithlet in forum Samsung Galaxy S4
    Last Post: 05-06-2016, 11:27 PM
  2. How do I root a Droid Turbo 2?
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 05-05-2016, 12:56 PM
  3. Note 5 no longer recognized via USB port to Windows 7 64 bit pc?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 05-05-2016, 03:46 AM
  4. Why is my keyboard dropping out on my Android tablet?
    By AC Question in forum Keyboards
    Last Post: 05-05-2016, 02:48 AM
  5. Why is my Android closing all apps and sending my to home screen?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-05-2016, 02:47 AM
