    I have a 2 year old moto g6 and the battery goes down when I try to charge it.
    07-07-2020 05:09 AM
  2. anon(10614692)'s Avatar
    Sounds like the battery needs replacing
    07-07-2020 05:16 AM
  3. Mooncatt's Avatar
    I would try a new USB cable before replacing the battery itself, as that seems to be one of the most common culprits for this symptom. You can also try cleaning the USB port on the phone with a can of compressed air, or something non-metallic to remove gunk from inside.
    BergerKing likes this.
    07-07-2020 08:08 AM
  4. Kizzy Catwoman's Avatar
    Please let us know what happens. Please register for an account so we can help you further. With a guest account, you can't reply. Thanks
    https://forums.androidcentral.com/sh...d.php?t=409154
    07-07-2020 09:29 AM
  5. B. Diddy's Avatar
    Welcome to Android Central! Also, are you actively using the phone while charging it, or does this even happen when the phone is idle? Are you plugging into a wall outlet or a computer USB port?
    07-07-2020 03:46 PM
  6. BergerKing's Avatar
    I see this problem all the time with bad cables. They flex enough times, or get dropped, then eventually will show up as slow charging, or charging, but battery percentage keeps dropping. Definitely check that first. Battery percentage can also drop if connected to a charger not powerful enough to charge your phone, but I'm assuming you're using the OEM charger here?
    [Thread moved to Moto G subforum.]
    07-07-2020 03:57 PM
  1. Replies: 2
    Last Post: 07-09-2020, 11:59 AM
  2. Is the Galaxy Store on my Samsung S9 phone a legit app?
    Last Post: 07-07-2020, 04:36 PM
  3. Auto-update apps on my LG V20 doesn't work?
    By Android Central Question in forum LG V20
    Last Post: 07-07-2020, 03:35 PM
  4. My phone's battery ran out completely and now won't switch back on
    Last Post: 07-07-2020, 03:33 PM
  5. Replies: 0
    Last Post: 07-07-2020, 02:48 PM
